Hi, everyone I need your help. I am new among you and I have a new Nissan Patrol 260 2.8TD. I can't decode VIN number of car and also I need manuals, or other DIY workshop documents. Can you help me?
Hi and welcome. What year is your vehicle? is it a Y60 by any chance? What are you trying to 'de-code' on the VIN? Where are you located?
Thank you for kind answer. I am sending my car pics. I am lining in Turkey. Attachment 79864
My win code is VSKWYG260U0523986 can you decode? Because i couldn't.
I need to know which one because I need manual of it :) To fix something by myself.
@AB, @MudRunnerTD, @munut , @mudski guys can you help with this one? Which manual download does he need? Y60/Y260? 1991 2.8L Turbo Diesel
@sarngon
Here is the decoded VIN for VSKWYG260U0523986
Make Nissan
Model Patrol
Model year 1993
Body style 5 Doors Off Road
Engine type 2.8
Fuel type Diesel
Transmission 5-Speed Manual
Vehicle class Full-size SUV
Vehicle type SUV
Manufactured in Spain
Vehicle specification
Body type Off Road
Number of doors 5
Number of seats 5-7
Displacement SI 2826
Displacement CID 172
Displacement Nominal 2.8
Engine HorsePower 115
Engine KiloWatts 86
Manual gearbox 5MT
Fuel type Diesel
Courtesy of Wiki...
The 260 series was a facelifted version of the Spanish-built 160 (easily spotted by the rectangular headlamps) sold in Europe and available in SWB and LWB with L28, SD33, RD28 and RD28T engines. The SD-engined version, at least in the UK market, had a 24-volt electrical system. Nissan helped Nissan Ibérica amortize plant investments. The 260 Patrol later received a facelift with a new grille similar to that of the Y60 series which succeeded this generation elsewhere. Spanish production continued until 1994 for export and until 2002 for the Spanish domestic market.
I would suggest the Manuals on here for the MQ/MK Patrol and the RD28T engine supplement would be the best, failing that an MQ manual for wiring etc and a GQ with the 2.8T engine should at least cover the mechanicals etc
ET, thanks for that, didn't even consider Wiki to be honest. Sounds like the 260 is a bit of a hybrid to some degree from some solid platforms.
Hi Guys
I recently tried to order some parts online and gave them my vin number JN1TCSY61A0365889 and Engine number TD42509988T as suggested to make sure i got the right parts
for my 2006 TD42Ti, only to be told that was not a TB42Ti but a TD42 as TD42Ti engines finish with an A rather than a T, so contrary to that bit of information i must be imaginings the inter cooler sitting on top and the bonnet scoop must be a bug collector.
So i thought i would have a look only to find out my vin number is incorrect and found nothing so as things were going from bad to worse i gave up as it getting late and went to bed. So i understand how you feel trying to find out what model your is.
Originally i was trying to find Nissan part numbers but i believe that will end up in to hard basket along with vin numbers.
Nice looking Patrol
