Hi All, I have a 95 GQ Wagon that will crank but not fire. It had reconditioned injectors fitted a few months ago. Spark plugs, leads and dizzy cap are about 6 months old, cleaned air flow meter and fitted pod filter 2 weeks ago, have just run injector cleaner through, rotor button appears ok, crank angle sensor replaced 4 weeks ago and ignition coil replaced Friday. It has pulse to the injectors and a strong spark but even with start ya bastard it isn’t firing??? It had been running a bit rough and a bit underpowered as well as idling a bit average at times hovering between 200 and 400 rpm, I drove it to work Wednesday and it just wouldn’t start that night???
