Family4x4
Slow but steady progress, as much as I have wanted to rush and lift the wagon body I have resisted and stripped everything I want from it as it will be much easier to access now as opposed to when it's resting on a trailer....It turned out to be a bit more than I planned....the hardest part so far has been undoing the electrical plugs...due to some minor physical limitations I spent an hour trying to undo one!!!
I wanted to keep the swaybar disconnect the ute had everything bar the bracket for the lever which attaches to the underside of the steering column...so I began stripping that out and have decided that the ute will also get the upgraded tilt steering column, (I bet that only ever gets used once)!
I also wanted the Jesus bar so dash out...the wagon had trailer brakes so that was stripped too definitely installed by an auto elec on an hourly rate...neat job and about 3 packs of cable ties in all the hard to reach places.
Clutch and brake boosters both fitted to the ute, ute also needed an accelerator pedal and hand throttle so they are in too
As I packed up this evening I took all of the tools out...apart from the trailer plug and fuel filler lines the body is ready to lift! I will have a crack tomorrow if I get time.
Hopefully the weather holds out so the chassis can get a clean and a quick coat of paint.
Big thanks to the forum and its contributors being able to search the odd bit of info for the best method of removal or install or just browsing other people's builds late at night for idea or while dreaming about how much of a beast this ute will be (it probably won't be haha) is a great help and motivator.
