2013 ZD30 CRD temperature rising when towing in heat
The other day when towing camper trailer 1200kg in 40 degree heat temperature was rising quite quickly to 110 degrees (on scangauge) on long hills. It was very hot outside and wasn't even cooling quickly on the downhill.
Car has only 60k on the clock. 3 inch exhaust. egr block. dawes and needle valve. Boost max 16 PSI.
When not towing temp will sit on 86 to 92 depending on outside temp and load.
Is this normal? The factory gauge got a little over halfway. Is it possible the scangauge was giving an incorrect reading in the heat?
