I have just bought a 98 GU Patrol with 159,000 km's on the clock in axcellent condition but I was aware of an oil leak which i thought may have been the main seal. When i took it for a roadworthy the guy pointed out that the tappet cover gasket was leaking badly and showed me all the oil running down the back of the motor, we figured that this is where the oil was comming from and fixed the gasket as part of the roadworthy. After having it at home for a few days i have noticed a few drips of oil comming from the hole in the bottom of the bell housing. I thought that it might be oil that has come from the rocker cover and had been trapped in the bell housing and slowly leaking out but i no longer think this is the case. Is this likely to be the main seal ? Is it likely to get worse fairly quickly if it is ??
