1 Attachment(s)
Install/Upgrade to 4" Snorkel (recessed) and new Pod Air Box
Replacing my 3" Safari snorkel with a 4" SS recessed snorkel and will also install a new airbox (w/K&N 9" pod filter).
Getting tools together to cut out 4" clearance hole thru inner guard and also the elongated hole req'd in the guard for placement of recessed snorkel. Might buy an air operated "Body (panel) Saw" to open out the entry holes.
Aluminium template is provided with the air box, that can be secured/bolted in place against inner guard and can be used as a guide to cut / enlarge the box entry hole. Yes could use hole saw set up but don't have suitable size. Need to also cut out a section of the radiator shroud/cowl as well.
Any one used a body saw for panel cutting and how do they finish off job?
Could buy a nibbler but thought the body saw may be a good tool option and produce less metal corrosive chips/swarf that could prove difficult to remove.
We’ve got one of these if either of you need to borrow if ever passing through @Bidja & @Hodge, AB had good success on his snorkel efforts I believe mates.
http://www.turnerprecisionengineerin...tachments.html
1 Attachment(s)
Tune/Dyno Result post induction upgrade
Now the 4" induction upgrade complete, went to ECPT (Tuggerah, NSW) last week, put it on rollers and had tune 08 CRD.
Have been progressively doing build up(last 15months). Stock eng except:
NADS
Remap
Procharge stage 3 h/f turbo
Tillix/needle (Max B 26psi)/13.5"Hg VNT actuator
Jonny Tig cooler
Ben Lipscombe - 9" K&N Pod / 4" thru airbox (3" to turbo)
4" fwd facing snorkel w/safari air ram
3" exhaust turbo back w/ muffler and cat
Had a couple of tunes along the way, latest being after install of JT cooler and 4" induction.
Running 33" m/t
Leaned it off from AFR19:1 back to 20:1, could have put more fuel but this has provided a good reliable result:
136rwkw and 512 N-m/4th gear.
Dyno results attached, my CRD "Blue Trace" / the "Red Trace" is for comparison purposes of a stock 2010 CRD on 33s and 3" exhaust on the same dyno.
Achieving 20psi Boost @ 1900-2000 rpm, max B 26psi @ 2200rpm (good to drive).
With the upgrade to JT cooler and 4" induction gave me an extra 70 N-m. From 378 to 450N-m and with the tune last week now producing 512 N-m. The trip back home from Tuggerah, NSW via Sydney (400km). fuel usage 12.5l/100km.
