Plasnart
OK this might not be new to you but I just learnt a new trick and was amazed how great it works when rotating wheels/tyres. Remove wheel, shuffle replacement wheel/tyre into place, then instead of heaving the thing up in a crouched position, then trying to rotate it around so you get a stud through, and busting a pooper valve in the process, do this: Shuffle replacement wheel into place. Slide a spade/shovel under the outer edge of the bottom of the tyre. Push the spade/shovel handle down, thereby lifting the wheel up an inch or two to stud height. To rotate, slide the spade/shovel handle left or right to spin the wheel until studs line up with the holes. Push the wheel on. So bloody easy and takes no effort at all!
Thanks to my old man I will use this trick from now on.
