G'day Forum,
I'm really hoping that someone will be able to help here coz I'm about ready to toss in the towel. Here are the details:
Vehicle:
11/02 Nissan Patrol Y61 GU Patrol
ZD30 Di Engine
Catch Can Fitted
Needle and Dawes Valve Fitted
EGR Blocked
Pyro and Boost gauges fitted
Recent History:
10000ks ago the head cracked, I bought a new head which came with new components (valves cams etc..a bolt on replacement). I put it all back together and has been running fine since did a 3000 k drive to SA and back with no dramas.
Problem:
Saturday, had filled up the tank on the Friday, drove down to the peninsula everything was fine, Saturday morning I was out in a paddock and lost power. The engine would idle but did not really respond to throttle, it would cough a little bit at full throttle but otherwise no response, no response to the warm-up switch either. No MIL showing. I tried priming the fuel filter and lifting off the airfilter cover to see if there was a restriction there but no good. After a couple of minutes of idling when i pressed the throttle the engine coughed a bit then started to rev up a bit rough, after about 30secs it was running normally. I figured it must've been something in the fuel so thought I would change the fuel filter, I drove back to melb and around on Saturday, got a fuel filter but drove about 140ks with no problems.
Sunday: Drove 5 mins from home and the same thing happened, I changed the fuel filter on the side of the road, no difference, it would start but only idle with the only response to throttle input being that it would get a bit rough but rpms wouldnt increase. Now I got a MIL and used the ecutalk to get the code; 76 Spill valve. After stopping the car this time, it wouldn't start again. I got it towed home and tried taking the fuel lines off, checking for restrictions or leaks - none found. I had a look online and some sites mentioned a filter that lived in the IP, however, I couldn't find one? I cleaned out some dust from the two plugs that sit infront of the back of the IP, no change. I tried hooking a funnel full of fuel directly to the inlet of the IP, it would suck fuel in when cranking but didn't fire. I've checked all fuses and they all seem fine (I couldn't find a fuse for the ECM on the IP though - should there be one?)
What should I do next? Any help would be greatly appreciated coz im stuffed as to what to do next - and i'm bloody sick of having the car in the garage in pieces :)
Phil
