Hi everyone
I am glad to join here. Looking to learn more from all members.
I need help please on this looking for distributor wiring color code for 8 pin connecter of the tb45 injection fuel . Thanks for all
Hi everyone
This is for TB45E. Note the 8 pin plug in the bottom left corner labelled F22 and the distributor (camshaft position sensor) also labelled F22.
Those should be the colours matching the plug.
Attachment 75635
These are the other numbered connectors for that 8 pin F22 plug.
Attachment 75636
Thank you it’s very kind from you. I am connected wiring of haltech sport 2000
Then you'll probably need the TPS wiring too but you can get that from the throttle body with a multimeter. Also MAF signal is easy to get.
I fitted a Chiptorque Xede piggyback to my TB45E but it didn't make a big difference. I have way more power now with the turbo diesel..
Your words are absolutely true. But Diesel engine does not available in my country and there are limited limits to the turbo mode for modifications cars.
What’s your location?
from UAE in middel east
They’re both very clearly marked in the diagrams. 6 goes to the ECU and 2 goes to earth.
Gday
Do I need to use a j121 ignition module with the TB45 distributor? I am using a microtec LT10 ecu and had this module on the old TB42.
Hopefully someone is still here!!
Jason
