Hi all,
Looking to replace the front GU "hook" with recovery points (front). Read a fair bit on here and sent threedogs a PM. Does anyone know if he is still doing these?
If not, for a 2016 GU Y61, the hook just has 2 bolts, vertical into chassis rail. The recovery points I've seen online (eg: roadsafe RP-PAT04) have 3 holes vertical plus a side horizontal hole which the GU has no-where to bolt that up. Are these just universal and you just bolt up the 2 bolts same as the hook?
I did notice on the drivers side there is also 3 holes with nuts welded into the chassis above the hook, but the passenger side has the holes with no nuts.
Any recommendations?
Cheers,
Shane
2016 Y61 Legend Edition
