My GQ patrol is fitted with the TD42 gearbox and the original transfer case from the TD28 engine, and running behind a Chev Diesel V8. On the last two times out with it I have had difficulty getting the transfer case lever to de-select from low range. This is a total pain as typically I need to drive it backwards and forwards then it comes free, however I am unsure if this is the actual solution or coincidental. Of greatest concern is the PTO winch which needs to have the transfer case in neutral before locking in the winch PTO - this is a bit different also as the PTO drives a HYDRAULIC pump off the gearbox; I needed to use the winch this last couple of days after blowing a tyre on a bad section of track and was too steep to crange it in-situ.
I am wondering what could be causing this? I note the front tyres are more worn than the rears, rears almost brand new, fronts maybe 30,000klm on them, Wrangler MTR, so tread depth would differ by maybe 5-6mm front to rear? I use the diff locks a bit also, so everything gets locked up to speak and can only allow on track slip to stock the wind-up? Has anyone else had this problem and what resolved it? I had the same trouble today just before ending the track, and backed up and forward for maybe 100m, then I did put the gearbox into neutral and foot off the clutch, and transfer lever slipped out without issue - wondering if there is a link between any of this?
