Starting problem with GQ 60 diesel .
Have replaced the starter motor thinking this was it , charged a new battery to 13volts ,same problem ,just clicks no crank . if any one has /knows the problem your help is very valuable .
Welcome to the forum mate , not much of an intro but sounds like your having some trouble .
Charging a battery to 13 volts means very little as to the state of battery and battery connections , to me it sounds like a dirty / corroded wire or connection at the battery or the battery itself .
Chances of buying a faulty starter motor would be minimal if new but not impossible .
thanks mate , yeah not the big intro i know ,but put some thing on the intro bit ....
yes new starter motor and battery fitted ,looked at all wires and seem to be okay but untested as yet ,chased the black yellow
Was thinking maybe a solenoid / relay problem or even ignition barrel ?
There is away of running a Hotwire from battery to starter but Ive got no idea how so hopefully someone will be along to help you out .
G'day mate. If you are confident in the starter motor and battery, try running a jumper lead from the block or the starter motor case to the neg battery terminal and try to start the truck. If that improves the problem you have a high resistance earth connection between the engine and the battery. If no improvement, try a jumper from the +ve connection to +ve on the starter motor. Connect to the starter motor end first and tap it onthe battery terminal. If that works you have a solenoid issue. You may be able to put that +ve jumper to the +ve terminal into the solenoid and operate the solenoid by using a smaller guage jumper wire to the trigger terminal on the solenoid. i am not sure of the layout on that vehicle but someone else will help out here soon. Try that jumper earth connection though.
It is probably worth turning the lights on and then trying to crank the starter. If te lights go dim then you probably have a bad earth connection or a bad battery, maybe high resistance internally. Probably not the ignition barrel, as that will only switch low current to the solenoid. If that was faulty you probably would not get the "click". Sounds like the ign switch is operating the solenoid OK but the high current/power is not being connected to the starter motor.
nice work 4bye4 . i will try that asap ,i through a screw driver across the starter yesterday but only got a click out of it
If you have already shorted the main +ve with a screwdrive and starter does not turn, Its a faulty earth to the starter motor, a faulty starter motor or faulty battery, even though you say the starter motor and battery are OK. Way out of left field, but the engine does turn I suppose, its not siezed is it? Or the starter motor not installed correctly and not able to turn?
just run the set up on the old startermotor and ran the starter,, But wont run the new starter.
being the new starter that iv bolted to the truck,,, we are all over this like white on rice
Is it a auto transmittion, it so it has a inhibitor so it so it cannot start in drive. Put it in nutraul. Then start it.
Manual bloke. Thankyou for all your help every one
Seems to be a faulty new starter motor and a faulty body solenoid under the tin plate next to the battery . The unit has a broken contact washer inside the unit (had to desolder the unit to find) .
Now chasing one down if any one in Rockhampton has a spare I'm looking.
Again thanks for help cheers
Just a small up date on the starter problem
Its was the new starter motor that failed ,bolted an old starter from another truck and bobs your uncle it fired up , now to sort out the blue smoke and wont come off idle
