Hi there,
While changing the engine oil the other day I found a little bit of fuel on the front diff (driver's side, on the pumpkin). After a bit more of a look around, it looks like it may be coming from the injector pump. Does anyone have any advice on likely causes? Is it most likely the seals in the pump, or am I looking at a rebuild? Or am I completely off, and could it be coming from something else?
Regards,
Christian.
