installing a a/c condenser fan on my GU8
Like most with 2012 crd's, mine doesn't come with a fan, so ordered a fan from wreckers, and checked out the plug taped to the loom by the bonnet latch.
My plug has 2 wires, green/yellow and purple.
Every diagram I have found shows a yellow wire from the relay to the fan and black to earth.
Have I found the correct plug? OR is there no fan plug on my model?
I have a cooling fan relay in the "box" by the battery, top row extreme right (blue). From the diagrams I have, it isn't wired for the fan, only the power side from the aircon relay. The fan main power has no fuse or wiring in the main fuse box by the battery, which obviously needs doing.
I have tried searching the workshop manuals on the forum, but not knowing what section code to look for, having difficulty finding the a/c section.
cheers
Lana
Hi Lana,
I went through the same process about 6mth ago with my 2016 patrol. The condenser fan is still sitting in the shed because, like you , I found lots of bits missing. I also have a plug in about the right spot but couldn’t establish if it was the correct one, certainly is different to the socket on the fan I have.
I have a Relim wiring manual. It only goes to about 2010 but I’ll try get some pics of the pages I was using for reference if you like?
I came to the conclusion that It probably wasn’t needed since the a/c in the new patrol is way better than in the old one (and it had a condenser fan!)
Trev
Well done Lana.
Did you already have a relay for the fan in the box beside the battery? (Mine doesn’t)
Could you throw up some photos of your relay locations and wiring?
Hopefully this fixes you ac woes. Let us know what difference it’s made.
Thanks for the diagram. I guess I’ve got no excuses not to do mine now [emoji848]
Trev
