jff45
			I wouldn't expect a TD42 auto pedal to be any different from a manual pedal.
If you modify your ZD pedal to take a throttle cable, I don't see any reason to get a loom redone. You can adapt your current wiring easily to fit to the TD requirements.. just depends how handy you are.
If using the ZD T4 torque converter, best to get it stalled a bit lower. I'm using a stock J6 TB45E TC. Your auto will need a good valve body or, at least, a Transgo shift kit.
Personally, at 300k kms, I'd rebuild it and add the extra clutches.
There are now a few TD42 autos getting around and there's quite a bit of info about them out there..
