Help wiring Tb42e loom into td42t
G'day fellas , I'm doing a diesel conversion ATM and am a bit confused on the wiring side of things, I have gq ti, the doner car the td42t come from is a dx so the loom hasn't got any of the ti options in it.. I've done some research and I see that you can use the Tb42e loom but I just abit confused about how to actually do it... so if anyone has done it and has pictures I would really appreciate if you posted them! Would help me out heaps! Cheers
Would that be the NATS gents? Is there a black box behind the pump?
I did a td42 to td42t conversion so used all of my bolt ons but I remember someone had a similar question here and it was the anti theft system on the td42t and they had to remove the black box behind the pump but someone needs to explain this better than me if that's even the issue?
Here you go mate...hopefully this sorts you out.
http://www.nissanpatrol.com.au/forum...ho-Not-Working
