DickieO
I placed the manifold on my spirit level and could notice a 0.5 - 0.75mm difference from the front to back, when undoing the manifold nuts i noticed the two back ones where the soot was were so easy to undo nearly no effort was require, the others were reasonably tight.
Luckily none snapped into the head.
I was under the impression machining the manifold was ok? and if its barely noticeable my half a mm difference has me believing I have a pretty seriously warped manifold.
If thats the case, anyone know of quality brands of aftermarket manifolds?
And if I’m replacing the studs for the manifold, whats the best material for exhaust manifold studs and nuts? e.g. mild steel and copper nuts?
