Can any body tell me what size bolt I need for
for the engine mount brackets are they fine
thread or course thanks in advance
its a 3l Di
its a 3l Di
I wonder if they have the size in the service manual Roofy?
................on the road
I'm sure mudski has some new mounts ... He can check bolt sizes , measure up etc ... Maybe ? @mudski
The mounts don't use bolts, they have studs in them. The bracket is bolted to the chassis. I just check the parts catalog and theres no size written. They will be a metric fine thread. Are all the bolts missing? both sides? I think they are a 14mm head on the bolt, which should be a 12mm (1.5 pitch I think) by maybe 20mm in length. If you can get another out you can use this for reference.
11298VB912 for LHS and 11298VB913 for RHS, are the OEM numbers. 4 each you need for both sides. Not sure why they are different part numbers, most times I see this they are the same part, just different numbers. See if a local Nissan dealer ship can get them? They might be cheap enough from them for the right ones.
Thanks mate yea four bracket ones where missing the ones that bolt to the motor
was very lucky the motor didn't twist out
ITS done now I have to wash the blood off the motor and me
hate 3l motors with a vengeance
shouldn't come loose this time used lock tight
Good work Roofy remember those things being a right P I T A ! ! Probly why they came undone, wasn't room to swing a flea in there . . .
Top stuff mate. Now come around and pull the motor out of mine will ya!
i would have fencing wired it...
Cable ties
when i was a teenager got pulled over by the cops...lifted bonnet and we had engine wired in like a strainer,corner posts...twitched with a long bit of wood against engine block.....impressed him our ingunitty but he still stickered the good ol charger....IF it ain't wire....it ain't wurff it
should have put the engine keep tryin to jump out
Gold AVO mate!! Charger 'V' :-)
Just catching up on this thread Sir Roofy.
What you need is M 10 with a 1.25 pitch x 20mm long
Hope that helps :bananarock:
Glad you got it sorted mate. Now off to Wonnangatta with you!
Do you know Phil and Zac Morrey from the GDSA? They are a father and son.
@Avo
Farmers + fencing wire = cover ups of a multitude of sins. PML
V ..... "Hey Charger". It had to be said, coz I'm old enough to remember. PML.
Luv ya Avo
