Hi guys,
I'm hoping someone can help give me some ideas of what else I can check. A quick background on what I have done concerning the clutch over about 3 or so years. Put clutch in and no pressure to return, searched and found slave cylinder to be the problem. Replaced slave cylinder. Clutch started slipping then wouldn't work so I put clutch kit in. Then discovered piston in master cylinder not returning so I replaced the master cylinder. Put foot on clutch and it went all the way to the floor without engaging clutch. Found a split in one of the rubber lines near the slave cylinder so I replaced that. Now the problem is that the peddle will go all the way to the floor but won't spring back. The clutch is engaging and I can change gears but I have to bring peddle back with my foot. I have checked the slave cylinder and it seems ok although I have noticed I can push the clutch fork to the slave cylinder with my hand. I don't think I had ever done that before and I thought it should be hard to do that. I also looked at the old master cylinder and when I replaced it I am still using the same push rod that comes out from the booster. What else can I look at?
