Is there a way to re-programme the timing of the intermittent windscreen wipers on a GU Y61?
As standard, they appear to have been selected by someone sitting at a desk who has never driven in conditions that require their use.
Bumped ,,,,, anyone???
Is it possible to put a "pot" in the system
to vary the stroke difference,, ??
Just having a guess....as some models have adjustable timing for the intermittent wiper setting....would it be possible to transplant the bits into one that didn't have it?
There are add on electrical kits you can buy to address the issue.
Yes, I agree. Most of them perform as the time intervals they work is "designed"(decided) by a pencil pusher that has never driven a car. It shouldn't be rocket science to design a knob that you can turn to adjust the interval time, but you can buy a one as an add on. :)
could you use the dimmer switch for the instrument pannell then all looks the same
i mean an extra one
Would nissfast have the info? Todd?
>>>tappin from tassie
Or maybe the OP has a DX model......
there are about 4 different settings on the left stalk you can use.
Ive found them to be adequate,,,,,,,
Maybe find what colour wires they are and fit the "pot" between them
I know what a POT is TD, so I'm guessing yours isn't like the bottom on in this pic then (which is from a GU ST wagon), the top one is from a DX ute
http://www.nissanpatrol.com.au/forum...017/03/108.jpg
http://www.nissanpatrol.com.au/forum...017/03/109.jpg
Is yours like this? There is a step in them but if been used a lot the step isn't very noticeable.
It is only 3 speed though not 4 like is said before.
yep same one Winnie, just went out and had a feel, there's one very distinct step, the other quite faint so probably why I never really noticed it before, actually time it as well, slowest setting is 11sec, next step is 8, next is 5 and the end is 2 seconds (also timed between the positions and get the same times)....... makes me wonder if the RX was indeed the same then, but I had a round stalk on that one......... so now I understand what @threedogs is on about (for once hahahahaha). I can only presume that all Patrols variable wiper stalks are the same stepped type then.
So if the OP has no stepped variable wiper speed then I guess he has a DX stalk
this is the other style for the GU I found
http://www.nissanpatrol.com.au/forum...017/03/110.jpg
@Clunk happy you now "get" me.lol lol
Mine is the same as the bottom stalk, GU ST
It's a 2015 GU Y61 ST. It has intermittent wipers but they are only at several preset switched intervals which I cannot change.
I am assuming these settings would be in the computer somewhere and should be editable, rather than a separate control unit, but that may not be the case.
I will have to investigate further or have a chat with a Nissan man next chance I get to see what (if anything) is possible.
with intervals like @Clunks why would you
change it I must be missing something,,lol,,lol
It's mostly the first one in my case. The time is so short that there is a barely perceptible pause between sweeps - no different from running slow speed continuous.. The others are around 4 to 5 seconds, 8 seconds and about 15 seconds.
Ideally I would spread them out to something like a 2 second pause between sweeps min, up to around 12 seconds max.
This is not something that I am likely to slit my throat over. I just though that I would ask if there was a way to do re-time it. Looks like the short answer is 'no'.
I can understand the need for say a 15 sec delay, I tend to just give it a flick when visiblity
is poor. There is not much between on and the quickest sweep. Like youself I can live with it
Makes you wonder who said all these intervals are correct for Aust conditions,,,,lol
