I found a pretty good article on the
www.wranglertiforum.com site. Quote below. Light output governed by current, controlled by led controller, so output is independent of voltage as long as its within the operating range of the lightbar.
"Do not get the idea that if you apply more voltage that the LEDs should give off more light. The amount of light an LED gives off is determined by current, not voltage. The current at each LED is maintained within a narrow range by a device known as an LED Driver."
