If you want to monitor and log ECU, I have a 2002 Elgrand with ZD30 (non CRD ) so has OBD2 plug but Consult protocol. Bought a bluetooth consult scanner with OBD adapter from buyobd
http://www.buyobd.com/index.php?main...&products_id=2
Cost about $65 and took about a week to arrive. I use NDS1 on my 8 inch tablet which I have mounted above the dash. Run it it dash mode (when not using google maps) and display about 12 items continuously. Or switch to data mode and record a log to look back on later.
Sent from my SM-T355Y using Tapatalk
