hi guys im having a bit of a head scratching issue here. MY GU td42t wouldnt rev over 2k properly. it would get to 2k then just loose power ( does not misfire). it will still boost properly but just would barley move. i noticed water in tank so i replaced the tank as that tank was stuffed anyway and new filter etc. i have cleaned gauze filter in pump etc. when i pulled the pickup/sender out of old tank the green tip/filter thingy was broken off. i ordered a new one however it was gonna be a while until i could get it and i needed car running so i added a inline filter just after the tank. car ran fine not a issue after this however it got to 1/4 tank and did it again so i pulled into servo added 20 bucks and the problem went away again. could me not having the green filter/tip on the pickup be making it not reach the bottom of the tank causing it to starve of fuel?
