2 Attachment(s)
		Amp install and placement
		Ok I promised pics of the amp install when I took the panel off again.
Im just chasing a alternator whine noise issue down that I have narrowed down to the RCA leads so I snapped some pics in the process while Im sorting it out.
This pic shows where I mounted the amp on the Drivers side rear quarter panel. I had no real option to install on the passenger side as thats taken up with the rear air con unit on mine. The photo isnt upside down, the amp is as that is the way I wanted it so it was easier for me to get to the High Pass and Low Pass filters this way.
As I mentioned before its basically 2 rods with flat bar that make the cradle on each side. You can see the nyloc nuts on the outside for the threaded rod.  Second photo shows the bracket better. The amp is recessed around 70mm inside the cavity. I have put flexible cable wrap around sharp edges to protect the cables.
On the right you can see 2 studs coming out. This is where my Earth has gone for the amp. I did have it on the main earth strap on the left but have since moved it due to the noise in the system. It has helped somewhat but still getting a ground loop from the head unit.
Things to watch out for:
You can see a little brown box under the amp. Its a controller for the rear windscreen wiper. I had to move it to get the amp in.
The cable for the Fuel flap release runs through that hole. there is more than enough slack to push it behind the amp out of the way and still work fine.
The rear windscreen washer cable also runs along the same path.
Further info: The white plug with nothing attached is for the factory CD stacker. Mine didnt have it in nor would I use it anyway so its redundant.
Attachment 68060
Close up of the bracket inside.
Attachment 68061
		7 Attachment(s)
		Home Screen Launchers for my head unit
		This post has been a bit delayed but here it is.
Few different Launchers (home screens) are now available to me. Some can be customized more than others. Wont go into too much detail as they all have the same basic functionality but some show more info, some show less. As you can see some show speed reading via GPS which I have found quite nice to have. A couple have weather read outs based on GPS coordinates.
One of them has extra trip computers which can be configured and triggered from the home screen. Another handy thing for them is you can stop them and start them. Handy for me checking on fuel consumption between gas and petrol when flicking between them.
Obviously the backgrounds can all be changed. Some apps can be placed wherever you want on the screen with a few, some other launchers only allow them to be just moved into one or 2 spots.
The one I am running on the most is in the second pic. The others I have just mucked around with and not much more. Themes can be downloaded for I think 3 of these launchers as well
Sorry for the reflection in the pics. I have also included a pic of the radio app
Attachment 68217Attachment 68218Attachment 68219Attachment 68220Attachment 68221Attachment 68222Attachment 68223
