Blowing Blue/White Smoke....is my Engine dead?
Hi Guys, my 2.8 GQ patrol has been blowing plenty of blue/white smoke recently, Its not hard to start, I have a to wind up the choke for about 20 secs on cold mornings and then its fine. But blowing smoke when I first crank it over, then there is a small amount of smoke on idle but getting huge plumes of smoke when turbo is spooling up and in between gear changes. Ive put about 2 litres of oil in it over the past month. There is a small crack in the air intake pipe where oil was leaking from just before the turbo which the previous owner just bogged up with gasket goop. Also getting plenty of oil coming through the crankcase ventilation system. I spoke to Mike Vine Turbo @ Capalaba and they seem to think that its possible that the turbo has been sucking in dirt and dust through the crack in the intake pipe and into the engine...which in my mind means the engine is toast. I then spoke to Diesel Australia @ Slacks Creek and he recommended a compression test, but thinks that the engine could have little to no compression. Am I better off getting the compression test done and going from there or should I be looking to source another engine to dump in there? any information would be greatly appreciated
