Cuppa
Hi Dom,
I was pretty sure someone would post what you have in reply to what I wrote. It is what I would have expected too, but my experience suggests different.
I have learned over the years that there are smart chargers & smart chargers! Not all work the same. ’Smart’ can mean different things.
All smart chargers will be multi stage chargers, & it is not unusual to see the term smart charger used to just mean multi stage charger. All should when fully charged drop into float mode, generally providing a constant voltage between 13.3v & 13.8v (with a 12v charger) with little to no current
Most will have a voltage threshold below which the charger will switch back into bulk charging mode. Some will drop back into float mode when a voltage threshold is reached. Some will just remain in bulk charging mode for a set period of time. This runs a risk of overcharging.
The 7 amp ctek I had automatically changed from float to bulk every 10 days regardless of battery voltage. This would have been ok if the battery capacity had matched the charger, but as the charger was too small somehow the charger always thought that the batteries needed charge & if left in float mode would have overcharged them. Essentially the charger was ’too smart’.
If the ctek was left connected to my batteries when the vehicle was outside the solar regulator would periodically show a high voltage disconnect error, whilst still logging the battery voltage from the ctek. On occasions this would rise to as much as 16.1v leading to concern about the possibility of thermal runaway & even fire. This was a result of mismatched charger to battery capacity. I can’t recall more specific details, but had correspondence with Ctek at the time & am confident the charger was not faulty. They suggested I test it on just one of the 150ah batteries (instead of the two of them together) & there was no problem. Together 300Ah was a different story. I had expected that a smaller charger would just take longer to charge them, but there is clearly more to it than that.
