Foldout Solar panels wiring questions ...
So, I'm going to utilize the solar function of my Redarc BCDC1225...
BCDC is wired as a normal dual battery system now, only fed off the alternator ...
The end result will be this setup. With an anderson plug at the front of the car. Together with the switch over relay which arrived today.
http://www.nissanpatrol.com.au/forum...id=64452&stc=1
http://www.nissanpatrol.com.au/forum...id=64453&stc=1
My question is in regards to the solar panel.... Mine arrives wednesday, but they have the similar setup to the photo below...
Now do I by-pass those control boxes all together on the panels, since the BCDC will be doing the "control" work, or do I leave it as is, and plug the panels in as they are ??
So on the photo you can see a cable going from right panel into a "junction box?" on the left and then into the control box... Is that
a series wiring, or are the panels paralleled at the black box on the left?
As above I dont have my panels yet so don't know the exact setup. Trying to set it all up before weekend as I am going away now and weather will be solar-perfect ...
http://www.nissanpatrol.com.au/forum...id=64454&stc=1
