Dannyboyz
Just an update for anyone who is interested, on the control box for the AP60 there is a small loop of black wire with both ends running into the box, in the instructions it says that when using the magnets, if the speed that the CC engaged at is below 40kph, to either reduce the number of magnets or cut the black loop wire. As I'm trying to use the speed sensor and my cruise would only engage up as far as 45kph, so I cut the wire, now it has a max set speed of 94kph (GPS) however if I hold the set/acc button it will accelerate up to around 110kph then cut out. So I'm sure I can make it work up to 100 but I will have to ring Command and see if there is any further calibration that can be done on my end.
If you are interested, check back for an update some time tomorrow avo
By the way, it sits on 94 like a dream, cruise holds it steady as a rock
