Brake proportioning valve adjustment
Finally got my longer brake bias bracket in but have no idea what the correct adjustments are?
Is the spring supposed to be tight, closing the valve or should it be a little looser so the valve is open?
Hope that makes sence lol ??
Im thinking the spring should should be tight so when weight is added to the tray, the spring will loosen and open the valve. If its open, its only going to stay open when the tray is loaded isnt it?
Pretty much no point in even having it if thats the case or am I missing the point?
Cheers for any advice!
