GU IV 3.0 Oil Cooler Leak?
Hi all. Recently serviced my '06 GU IV 3.0. About 2 weeks later I've noticed a small leaking of oil. I've hosed and degreased the underside of the vehicle as the oil drips and leaks onto the diff, motor and even hits the exhaust (this is what brought my attention to the leak). It appears to me it's the oil cooler gasket as it's just slightly towards the right side of the oil filter drip tray (if you're under the car). Filter is tightened to the correct nm as specified by the manual, right amount of oil was put in and all seals were lubed up. So apart from the oil cooler gasket, I have no idea what the leak could be as it is minimal. Any recommendations for a service center in Melb that can help with this issue would be appreciated. Thank you.
