The Alternator has just died and I want to know what size I can replace it with and just swap in swap out no other mods .ie 100 amp or larger Sorry a bit more info helps 1999 gu ute td4.2t
No takers surely someones upgraded.
Ill jump in ,surely a 100 amp job will be a straight swap , Ive noticed some give you
an extra plug so its a straight swap . Ill find a link for you
http://www.ebay.com.au/itm/New-80Amp...oAAOxyMd1SEYne
http://www.ebay.com.au/itm/Band-New-...gAAOxyWalR19uN
heres a few options for you
I have put a Patrolapart 120A alternator on my GQ TD42
If you put a bigger alternator on you will have to run another cable fused from the alternator to the battery, or else you will blow the main fuse if you are pulling the capacity from the alternator. Happened to me when winching.
Winnie what size fuse mate ?
3Dogs doent need the vacumn pump and would you stay with the bosch unit even if its more coin as thats the way I'm leaning at this stage .
You really need to buy the best you can with whats available.
some may have better warranty, I think my OE alternator cost me
around $450 I think could have been cheaper, I forgot to tell them
to fit a larger 100 amp job at the time my bad eh
O.K a little learning curve for me knowing nothing about electric matters it turns out that my twin battery setup is 12 Vt in-series running off the accessories side .This means when the back battery dies it creates a open circuit that drains the primary battery as soon as .My symptoms were main battery died after 15 min. then tested alternator and got a reading of 10.2 Vts .Step 1 new primary battery no good step 2 new Alternator still no good , the second battery was holding a open circuit ,maybe Yendor or a auto lecky could explain in a bit more detail but am grateful too my boys coming over and helping the Old Jumby out after 12 hr night shifts .
