GUIV Fuel gauge has false reading
Hey guys,
so the mighty GUIV is now relegated to being driven by the wife as a daily which is Ace cause it will keep the Kms down on it. Freeway commuting kms SUCK.
I drove it on the weekend and noted that it needed a fuel up but didn't get around to it. the full light was on when i pulled in the drive (I know I know, i should have sorted it... but i didn't).
Today Naomi was driving the daughter to daycare around the corner and it cut out. She had trouble starting it and ca led me, it turned over a heap then fired so she got in and drove while i was on the phone. It was sluggish then stopped and she parked it and walked.
Sat there all day as i was in Melbourne. Got home tonight and tried it, primed it and after a bit got it going for 10m then done. Ended up on a tilt tray back home.
So talking to Naomi trying to figure if she had got some bad fuel somewhere?? the gauge was showing 1/4 of a tank......
NO WAY!! when i got it home i started at the fuel filter and checked for prime then supply and clearly it was empty. 20t jerry later and its good to go.
SO! Bloody thing! i have filled it up and filled the Sub, i have always filled both and Always wait for the light to come on the pump the sub and empty both tanks every cycle pretty well.
What can i check guys?
