Doing a twin pot upgrade and I am reconditioning the calipers and have mixed up the slider frames when painting. I think the term is correct but the frame I am referring to is the bit that the pads fit in.
The questions.
On the drivers side does the slider frame have the pin whose rubber boot goes all the way through the frame at the top or bottom when mounted?
Does the caliper when mounted have the bleeder at the top or bottom when mounted?
