Hi All,
I'm considering putting 33 Maxxis on my stock GQ shorty but will they fit or rub?
Do I need to get a 2 or 3 inch lift for it to work?
Thanks.
Hi All,
Thanks.
Mate this is such a hard one to call for ya. It depends on rim offset as much as lift. I've had ppl tell me 33's rub on 3"lift & I've also had ppl tell me thay run 33's with no lift with no problems.
It will depend on your shorty most of all so talk to your tyre ppl work from there.
Best of luck
Paul
Cheers guys, might be a bit risky at this stage as I cant afford to do much more then a new set.
Might just stick to 31's for a bit...haha
Has anyone here actually put 33" tyres on stock GQ and not rubbed?
Getting a 3" lift in the next few weeks but was considering putting a set of 33" Mongrels I have in the shed on tomorrow to see how it goes but am I just wasting my Sunday?
I don't think it would be possible, particularly with the factory wheel arch flares and mud guards. With my 2" lift (possibly more like 1.5") my 33" muddies rubbed on the flares and guards. Might just get away with it if they are road terrain tyres ie. rounded edges without any protruding lugs and without flexing too much. Even with my flares and guards removed, my muddies still just rub on the top of the rear wheel arches at full flex.
Cheers mate, yeah I thought so but just checking if anyone has actually done it before...I was going to pull the flares off but I'll just wait until the lift gets done in a couple of weeks.
Impatient bugger I am...lol
hey guys i just put 33"s on my stock gq i took the flares and mud flaps off not rubbing 15x12.5 on 8" rims
I'm glad some one else is having a go at this, coz I've alos gotta get new tyres soon, so was wondering should I get the lift done first or tyres first................ either that or just get another set of 31s then that way I'll know they'll definitely fit and just wait a couple of years until the next set
yeah im looking at lift kits im thinking 3" just to get the gas tank up a bit higher
3" is plenty to get 33's under .. And a good size lift also for looks and drivability ... Make sure it's setup for what you do - that is, if you're expecting to do hard track work, then get something like flexi coils, a mix of all things Australia like beach, bush and touring, potentially go a soft long coil in the back for flex, and a medium coil up front for stability (that's what I have) and that the shocks are matched to the springs. At 3" you'll need a caster correction kit and panhard rods etc, but at 2" you can avoid changing them - just a decision on how much you want to spend really.
Good luck with it and make sure you throw up some before and after snaps for us to ogle!
and radius arms.
Always good to change them over if you can afford it, but for a 2 or 3" lift you won't need to. I am above 4" and have the stock arms, but the wheels have moved centre back in the wheel arch - eventually I'll get some drop boxes put in, which is a cheaper option than swapping both arms. From what I understand (Tony? Anyone?) if you put dropboxes in at the outset you'll also avoid the need for a caster correction if only going 3" ... Well worth it as the caster correction is a few hundred on it's own.
I had offset bushes done but still scrubbed at the arches from my exeperience and wheels don't look centre as I have a slight rake like the landcruisers :)
if I slightly raise the front it might be ok
Superiors standard drop box suits 3 to 5" lifts. They actually drop the rear radius arm mounts 90mm so if you lift the car 90mm your steering goemetery will be standard. The drop boxes also move the radius arms forward about 12mm which helps reduce scrubbing.
There are advantages and disadvantages to the various forms of castor correction but I don't have time to go into it at the moment - this whole working thing is getting in the way of my forum time!
Tony
I got a full suspension kit from bigO4x4 as described in other threads all the gear, running 33's and can get them to schrub on inner rear wheel arch...... if you got the flex you'll touch. But i still want 35's next time around. (4"lift)
here's some pics and info about stock GQ on 33's
http://www.nissanpatrol.com.au/forum...1224#post51224
I just put some 285/75/16 Kuhmo ATs on and they are much smaller than the 285/75/16 Insa turbo muddies (although still pretty big). So I think with the smaller tyre, rubbing wouldn't be too much of a problem. But with the extra size of the muddies, and the huge lugs that stick out of the edges, a 2" lift minimum is required. I think with the Insa tyres, maybe they started off with 285/75/16, but they stuck another 20mm or so of rubber on when they made the remold LOL!! As they are seriously heavy.
thanks guys for the great info I have been thinking the same thing about fitting 33 inch tyres
My friend fitted 33's on his LWB Gq with 2inch HD suspension lift. These only just touched his flares on full travel, he trimmed them and it did not rub again. This was with a -22 offset rim.
if you have a less offset rim the tyre might hit more.
if you have the skinny 33's (285/75/16) it might be easier with only a 2inch lift and 0 or negative offset rims.
