No indicators AGAIN - Help
I need some help from the many experts on this forum as this intermittent problem is driving me (and my auto-electrician) nuts! I use my 2000 4.2TD to tow a horsefloat. On several occasions, when towing, my indicators/turn signals stop working….not safe when towing huge horse float. Auto electrician changes a fuse and checks that everything is OK and away we go and then a few trips later, it does it again. Luckily, I always notice the absence of the ‘indicator ticking’ before we are far from home.
Background – have had float since new (2003) and this has only been happening in last 12 months. Had same AE do a thorough check of all electrics in Patrol and float 3 months ago. Replaced electric tow unit then. Float has only been towed with my Patrol. Patrol never tows anything else. (I know…boring life for my Patrol, compared to what some of you get up to!) Brake lights, headlights, tail lights still work…just no indicators. This only happens when I have the horsefloat attached, but not on every occasion. Damned intermittent faults! When I got my Patrol in 2003, it used to blow the indicators if I pushed the hazard lights button. I got it fixed and have avoided using hazard lights, but mention it in case it is linked to my current problem.
Any suggestions?
To trace it - do you have any friends with a float you can borrow? If yes then replicate the exact conditions (eg weight route speed current draw ie headlights etc) that you had on previous outage incidents and see if it happens again...
If not problem is from the plug on the float all the way to the tail lights. If that the case use a multimeter on each individual component check for continuity if any give you a reading that's the short circuit you can then trouble shoot from there.
If however it does happen it's in the truck under towing conditions, you've already replaced breaks unit so not that.
it's only indicators?
Once the float is off do they begin working again?
Again if yes to the second it's most likely your tow connection plug or the trailers or overloading the turn signal relay or flasher unit could also be happening.
To check the flasher it's the square thing above and to left of brake pedal. Check the earth out the back of the unit and also follow the other wires coming out of flasher away from ignition until you hit the signal switch, check them and the earth at the back of the signal switch as well.
With towing it's tricky as there are heaps of different forces on the truck. Not only is there the drag but there is downward force at the rear which makes you drive in the truck at a different angle. Corners snd wind add new lateral forces and the thick is using more energy this generating more heat in the moving bits, which share a lot of common space with electric bits...
Intermittent blows because it's hard to do the first diagnosis.
Previous issues or hazards also compound the problem identification. Gu's have the hazard fuse under the bonnet whereas other models are typically under dash..
Here's the turn sig trouble shooting although I suspect you've got a plug / trailer short or loose connection that wobbles etc and loses contact occasionally but is not visibly obvious..
http://www.nissanpatrol.com.au/forum...2015/08/78.jpg
Good luck
