1 Attachment(s)
Zd30 power loss.. cnt even pull skin off the custard..
Hello there fellow patrol family.. having bit of drama with this pootrol of mine... now ever since i bort my bus it had a random high idle... aftr a few months and a few dollars latr i finally found and fixd the problem.. it seems it was a faulty throttle position sensor dwn by the throttle pedal assembly...yayy... but just resently on another note it has lost power.. (was doing it befor i replaced tps) i thought it might have been leaking intercooler so i replaced with an aftrmarket one wiv the end tanks tig welded up.. im seeing a solid 18-psi on my boost gauge with my dawes and needle valve set to just open... but it feels like a slug.. i can barely get it to hit 80ks downhill... lol.. and further more its drinking alot of juice... tryed without dawes and needle valve.. boost is all over the show.. the lighter the right pedal the higher the boost goes up... (if i feather the gas) but then when u go to put your foot down boost actual drops off right dwn to like 5 psi.. then if u let u foot of the throttle and back on it will instantly shoot upto 15psi... wasnt liking that so put dawes and needle valve back on...
Heres whats on the motor so far...
Blocked egr
Dawes and needle valve.. sits arnd 18psi...
Hpd catch can
Hpd maf housing and lid
Aftrmarket intercooler
4 inch stainless snorkle all the way to the airbox
manter dump pipe bakto standrd system
Ok heres what ive done...
Injector pump
Cleaned maf
New battery terminals
Extra earth straps
Replaced all vacume lines
fuel filter
Oil filter
Air filter
Replaced tps
Replaced factory intercooler
Glow plugs
Injectors
Ecu and glow relays
Checkd and tidied up all lose/messy wiring
Disconected batterys for a few hrs multible times
Getn a ecu talk which will hopefully help wiv diagnosing problems... but im thinking if its boosting ok.. then it must be a fueling problem... cleaned the maf few times with no noticeable difrence... thinking might be faulty.. anyone knw where to source a replacement.. refuse to pay what nissan charges for anything...
Any help/suggestions much apreciated...
Attachment 59568
Sent from my SM-N915G using Tapatalk
