24V dimming light neagtive earth negative body giving 12.5voltage
Hi there. Any updates on this topic what was the fault? I hope safari didn't die. I am new owner of Safari and I am experiencing after 2 years of ownership same problem. I get from negative battery lead and from chassis earth 12.5Volts leaks from somwhere.
My problem start when I decided to put led bar on it. I installed everything and it worked ok and suddenly after 3minutes I got on dash warning light on red battery and yellow fuel filter. Now the warning lights are dimming I started to investigate what could happen. I pull off all LED bar harness away. Only what worry me is that i poked firewal with harness in order to install switch. Could I possible damaged wire inside the firewall? and now is shorting in there? When I remove Alternator fuse in engine bay the voltage leak disappear but not fully. There is still on negative to negative 0.7volts leaking. Could be damaged alternator diod on it or something giving these symptons? Interesting is when I switch headlight on it jump to 12.5volts without alternator fuse. Battery is healthy shows 12.7V. Please someone help me to diagnose this problem I know this is strong community and someone is here with similar problem.
