TD42 build about to start. Need some direction...
O.k
I think I need to get off my bee hind and start with this TD on mine thats only been sitting here for well over 18months. As I get the coin from now on I will be putting it aside to do bit by bit this build up.
So what I have here
- is the block with the liners still in, camshaft still in and the oil squirters.
- No head but thats sorted. Got an OEM head lined up complete with teh lot.
- Rebuild kit, also sorted.
- I have an IP pump that needs a rebuild, it has no compensator so I am assuming I can get one put on???
- Need a turbo
- Intercooler and hosing
- Injectors
- Alternator
- A/c pump
- Radiator
- and anything else I need. Lol
So first things first. I should get the block crack tested. I need to remove the liners, squirters and camshaft. How do I remove the liners? Anyone know someone in the northern burbs that can test the block? I might ring JPC and ask Mark there but someone here might know.
Thanks.
