Is there a place to put the thermo couple or could I use the adaptor in the link.
not saying thats the corect one but would be similar
http://www.ebay.com.au/itm/Water-tem...item25a004793f
That's similar to the one I used, not leaked in 4 yrs
That one is for a WRX... it will only work if you have a 12 inch exhaust tip, Jet Pilot Stickers and 21 inch rims.
Hahahaha... love it.
I brought this one
Attachment 55013
Still need to get wire and make up a box to fit the gauge that will house some rocket style switchers as well.
John. Just curious. Why? Can't you read your water temp through the scangauge or whatever you have ? That's how I read my one.
@ Hodge its a grey on green display on the ECU-Talk hard to see at the best of times.
I think a single cup above the pillar gauges I have now will work.
On advice with my efi motor I did not use one of those ... I prefer to tap and thread.
The td42 has the perfect spot (thanks matfew for pointing it out) and looks factory rather than cutting good hoses all the time.
Attachment 55034
John on the thermostat housing pipe there is a threaded plug where i reckon you can put a sender in. I have a housing here i bought ages ago with the intentions of fitting a gauge...
I can take a pic if you want....
