Hello guys and girls, hope everybody had a blast over the xmas break. I did a few klms in the patrol now time to give her a service. Is there a huge advantage to using k&n air filters I am looking at changing over to them
I have now two K&N filters that I alternate before every service and after every bush,dusty trip as I would like the vest airflow possible.
The Nissan paper filter is a great filter for normal road driving.
The best advantage is not having to buy another filter as I just wash clean and re oil the spare filter.
You do get a little more power with the better air flow, and for a 3lt you need all the power you can get. Lol
I do exactly the same....
got one in my TD42 but unlike the rich bastards above, I keep a paper one as a spare for when the K&N is being cleaned up etc etc etc
How do the sensors go with the oil fumes ?
Remember a post a while back when fumes from something affected a sensor,
might of been using sikaflex not 100%
$42 out of the Uk delivered to my door. For a filter.
Agree but with a rider for engines tha are known to be sensitive to MAF issues...
Don't use too much oil when you load the filter after a service and definitely don't put the filter staright back in.
Give it a 1/2 hour or so after oiling.
On my Chevy I could probably start it up and tip a litre down the snork and let God, Gravity and Dumb Luck sort it out but on the other end of the scale a CRD?... not so much
I can remember a thread a while back about fumes , but I think ET hit it on the head
by not replacing the filter straight away, and not applying too much,
Maybe some are thinking of those foam re usable filters
With the spray on oil is quite easy to use and not over oil the element... Plus having two elements the second one has been sitting for a while pre oiled so it's good. But yes you need to leave them sit for a while before you put it in.
Also, one of the reason why I use these filters is there is less rubbish and I can simply change my filter even after being on for a week if I want to because of a dusty day out in the bush.
Sorry for not replying earlier. You all talk about being good for diesels, I have a 4.5ltr petrol would it be the same for it.
The evil twin all good :) I understand
