Hay everyone found a bigger sub tank out of a 2000 4.2 wagon just wondering will it fit in my 2008 crd 3L wagon
According to LRA's website, they are all the same for the wagons from 1998. So I reckon your safe.
http://www.longrangeautomotive.com.a...art&Itemid=214
I reckon you should be ok is it 70l,s
as long as its a GU one, you will be ok
my long range tank came out of a 4.5 petty
a bit of a mess around to get the original tank gauge to work.......... but it did in the end
Well worth the effort though. It's probably the best upgrade I've done on my tb48. I use it every time I fine the car ;)
Attachment 53446 not sure on the size and thanks for the in put everyone
i reckon that one pictured is probly for a ute, looks way too tall to fit under a wagons floor
Old mate said it's out of a wagon and won't fit in a swb ute
Looks like mine, will be ok
So that should be a 70ltr stropp? Would it bolt straight in and use the same sender and plumbing?
Ok cool thanks very much guys
Yes it will use the same sender I think its negitive off when empty.
Dont rely on the gauge too much the first half of tank is a bit iffy.
I have the Brown Davis 75ltr Aux tank, my range is about 1100 now I would think
You just bend the sender unit's dip stick arm John to suit the deeper tank. Mines sitting here and was supposed to go in before this monday when we go away. But it still needs a inside clean, a fair bit of surface rust in it, and I don't have time to do it. Just wondering how long it will take to do the remove and refit.
hey guys i think that is the belly tank for when they put in a lpg tank in the rear
only saying this because had this in my 95 gq and what gives it away is the exre square bit on the end
with etra bit was 90 ltrs
without 70 ltrs
Attachment 53575
Hay guy is it ment to come with another bracket or something the filler pipe hits on the rear mount and carnt see where the 2 rear mounts on the tank hook up to
How did you with the Install sr06? I picked up a tank today and it looks the same as yours and am looking for any tips. Did it bolt straight in?
