Kinda stuffed the crank what are your thoughts should i
A: Just get the crank replaced and keep the 2.8 there is nothing else wrong with the motor
B: 4.2 conversion
C: Ls1 conversion
B: 4.2 conversion
C: Ls1 conversion
would really depends on funds available.
Were you happy with the performance of that motor??
three dogs ive never had any issues with the 2.8 motor yes its sluggish and can struggle with the camper going up hills but you just drive within the capabilities of what you have having said that the engine is modified and most people ive been 4wding with that didnt know the car couldnt believe it was a 2.8 till the bonnet went up but i drove a mates 4.2 and another mates who has done the ls1 converstion and have to say the power of the ls1 impressed me but im old fashioned and cant shake the notion that 4wds should be diesels my young bloke is just finishing off his Ls1 converstion and keeps telling me thats the way to go just so confused guess i will do the ring around Monday get some prices and see where i stand from there
chuck a 6.6 duramax in :)
You could also get your crank repaired. It looks as though it's only the balancer section that's stuffed which is lucky cos if the timing gear section had let go it could have been messy.
Cheapest option will be repair/replace crank. As you will have it apart I would chuck some new bearings in at least.
Looking from this angle looks like a new crank
what side of town ore you on,?
depending on what you want to do if you want to do a lap I would suggest diesel.
If you only use it for weekends away and shorter trips under 1000 K then the ls1 may suit you better
I'm sort of going through the same dilemma even though there is nothing wrong with my motor ATM.
I also want to convert mine into a dual cab but thats another story.
TD 4.2 would be nice as the value will go up I think or at least hold a decent price
A TD42 coversion from RD28 will also include a gearbox and transfer case as well. Yours is one of a number of RD28s that have the same damage. I have had a look for threads with info on successful repairs, but came up with nothing. I think someone had their stripped keyway welded.
Hopefully you are correct.
Been a while i finally went with an L76 with the 6 spd auto engine out of a Ve ss.The engine should be in this weekend so hopefully have her back on the road within a couple of weeks figured the amount of trouble i had with trying to find a mechanic to fix the old 2.8 and the availability and the relative cheapness of the ls motors had nothing to lose based on on research and a guy i know who can tune the ls motors their claiming they can get 14 lt per 100ks out of it but we will see
Had the same problem just recently, common with Rd28Ts woodruff key lets go. engine still performing well like yours after a lot of research including replace engine the cheapest option was to strip down the engine have the crank titanium welded ,Why did i not just buy another second hand crank, ? because their like finding gold teeth in a chook, [though you might be luckier,] a new Nissan crank is worth an arm and 2 legs. you will probably need a new harmonic balancer of course, & if you decide to go this way replace your big end & main bearings as well. I also had it balanced, that has improved the power and fuel economy significantly, worth the extra $$ Replaced all the necessary oil seals & other bits & pieces too. Everything $ wise came in well under a second hand or new engine. Good luck mate Rob Ness
Hi it's a while back now i've got the same prob crank spun rolled wood ruff key broke edge off slot new balancer sloppy on crank at front but no movment at the back where it meets the crank timing gear. Gear also was on sooo tight it didn't move with the balancer. I have jb welded a new key and balancer back on to the crank yeah I know but hey it was solid although somewhat wobbly. Waterpump decided it was not happy about the current situation along with the cam seal.
Everythings back off just about to put seal in and reassemble I saw your post on here and was curious how your photos of the crank looked but can't seem to open the jpeg. I am logged in but the pointy finger doesn't replace the arrow to click on attached image.
Just went back to post and theres your image wow Iwas logged in b4 as now don't know anyway looks like mine Ithought for asecond Ihad posted photos of mine but I hadnt almost identical.
This is a pretty old thread and patrol 2.8 hasn't posted since 2017. I think you are taking a massive chance in using JB weld. If it lets go, the whole harmonic balancer might come off. I had a friend whose Pajero lost the balancer at 100kph. The balancer ricocheted around the engine bay and the damage was extensive.
My brother had the crank key shear on a land Rover Discovery at 4am on the way to work, pulley cut thru a number of looms and he escaped with his life by about 10 seconds - car erupted in flames almost instantly, melted into the bitumen. Keys are a major structural element not to be short cut.
