GQ 1989 TD 42 Recalls?
I bought mine second hand with 30k on the clock in 1990 and have never been advised of any recalls.
Have I been missed or have there been no recalls on the diesel GQ TD42?
Its almost run in with some 190K on the clock so I was just wondering if there is anything more I need to know on this?
Thanks in anticipation.
Chimo
The only real thing with that model was the panhard chassis mount. It was revised and a bracing plate was added.
There was a recall on my 1992 efi front brake hoses. Might be worth checking if yours has that due. Mine only got changed late last year as well.
bump ,,,,,,,,,,,,,,
Thanks for the help so far.
Looks like my VIN excuses me from the brake issues but.................
My next question. How do I tell if this is in need of fixing on mine or do they all need to be repaired?
Which welds need to be inspected and if plates were fitted where are they located?
Chimo
"Problem: WELDING CRACKS IN FRONT
PANHARD ROD
Make: NISSAN
Model: Patrol
Variant: Hardtop, Wagon
Date
Range:
1987-1990
VIN
Ranges:
Status: Inactive
Defect: Concerns diesel wagons built
17/11/87 to 22/6/90; petrol
wagon and hardtop, all diesel
hardtop built 17/11/87 to
26/7/89. Under severe usage
conditions the panhard rod
attachment welds to the
chassis may crack.
Consequences: Reduced vehicle steering
stability.
Corrective
action:
Inspect for cracking. Apply
minor or major repair
according to nature of
cracking.
Notif. Date: 20/08/1990
DOTARS No.: R90/033
Supplier Name: NISSAN
Campaign No.: R029#
This is a pic of the front panhard mount with bracket attached.
http://img.photobucket.com/albums/v9...A4AACFA18F.jpg
Thanks Parksy.
So if I understand it correctly, Nissan should fit one of the brackets as in your picture if they have not already fitted one to my GQ? Your bracket looks very new, has it recently been fitted?
Chimo
I found it on eBay for cheap so I bought it and painted it up. As far as I know, my patrol being a 92 model already had the improved panhard mount, because the bracket didn't fit at first. I had to modify it first to make it fit. But for peace of mind I've fitted it to mine.
Can you post a pic of your front mount?
Too dark even on the Goldy at present.
Will check it out tomorrow and I might even go see one of the Nissan dealers and see what comes of that?
Thanks again Parksy for all your help.
Chimo
1 Attachment(s)
Attachment 46620Parksy et al
My build date falls in the period of concern for diesel wagons but talking to Nissan this morning and they say no recalls for mine. Interesting?
Pics of my bracket which does look a little like yours Parksy.
Chimo
Yep that's the bracket. Happy days.
Poked the camera thru above the rod and took a heap more pics that I've blown up and the welds etc look OK so I guess given that the front end alignment was spot on when the new set of tyres went on recently I will move past this and just put my energy into surviving the whales and catching snapper tomorrow.
Thanks again for you assistance Parksy, much appreciated.
Chimo
