mudski
When you experience limp mode your car will have no power, at all. The only way to get the power back is to let off the go pedal and then back on again. What you experienced, doesn't look like limp mode to me. As even if you floor it nothing will happen when in limp mode until you let off the go pedal and back on again.
Have you clean the air flow meter at all since owning the car? If not I would get some air flow meter spray and clean it firstly. Second, if you can get a hold of a scan gauge or this diag tool to plug in and try to replicate the issue, hopefully this will tell you more.
Limp mode is a safety function the ECU uses to stop over boosting of the engine. In the earlier direct injection models, this was a bigger issue, more so than the CRD's. The function is still used in the CRD models but the ECU seems to control the boost a bit better than the older Di's.
