Hi guys
Just want to know how you have mounted an awning
To a arb style rack
Ron
Hi guys
To a arb style rack
Ron
Mine arrived with 6 bolts and washers included. Drill holes into each pillar fit. Let me know if you need photos.
Hi hodge
Do you mean the pillar that attaches to the gutter
Mine is on the a actual basket pillars. I've green circled it here mate. I have seen a few people install them on the brackets that hold the rack up above the gutters, but getting bolts in there would be a pain.
Also I think there is a U bolt mounting system, instead of drilling into the rack.
Attachment 43078
X2. Pillars on the basket.
Drill holes and bolt up.
Shops that fit them just bolt to the two outer pillars, I bolted to all 4 and when the bloke at the shop saw he thought I was mad... Lol
Sent from my GT-I9305T using Forum Runner
Yep I mounted mine the same way. Heads up, I fitted mine close to the bottom of the top rail. Pain in the butt. Leave it low enough that you can still use a hook or rope on the top rail mate. Drives me nuts. Any questions I have a full pictorial of an ARB awning fit up. I really should do a How Too thread.
I just used U bolts wasnt keen on drilling into a new basket
hey rickie3
did you just use standard u bolts
My ARB rack is getting replaced / warranty issue. So since I've drilled into it for awning and shovel holder, I might use U bolts instead of drilling to the new one.
Rickie any chance you could post apic of what U bolts and how exactly you dont it? Cheers mate.
