Rickie3
Had the IC preasure tested and it appears ok, so ive installed the dawes kit and blanking plate, ive followed the paperwork that Mark sent with the dawes, but am a little confused, it says wind the needle valve right open so no flow restrictions, I assume that means open so air can pass through? which I did, I wound the dawes in a tad till I couldnt hear the ball bearing rattling, I then went for a drive and the boost gauge didnt even move, so I pulled up and closed the dawes a little more, but still no reading on the gauge, so pulled up again and wound the needle valve right in then slightly out to roughly 1/4 inch and this time the boost gauge shot up to around 22 PSI, so pulled up again and wound out dawes a little and got back to a tad under 15psi, but have been hitting limp mode at 2700rpm, cruising at 100kph with accelartion sits just under 10 psi,can someone give me some quick guidence please where i'm going wrong
