HELP! - Popping out of First Gear
Hi Guys,
need your collective experience with this one.
When in low range first gear and idling down a steep track such as Billy Goat outside Dargo, my Y61 Gu 4.2 ITD kept popping out of gear, which at one point was a bit hairy to say the least at the time.
I've tried to research the fix and have found that the cause could be anything from the engine mounts needing replacement (????) to something more major.
Has this been experienced by anyone else?
What was the solution?
Appreciate any help you can give on this one as I'm prepping for a Vic High Country trip in June.
JR
