mudski
12psi at 2700rpm isn't overboosting. Is your boost going beyond your preset 14psi for starters? If so I eould start from the beginning. Open your needle valve right open, then set your boost level again. Ignore the sluggish feeling for now, just get the boost level set. Once that is done, wind your needle valve right in and start the car up. The rod on the turbo actuator should be sitting right up as far as it can go. Then start to unwind the valve until the rod drops about 1/4 of an inch. Take it for a spin and see how it feels and goes. The rule of thumb is 10psi at 100k's. Too low and the turbo will spool up very slow the car will still be sluggish and your egt's will be high. Too high and the boost will rise much too fast and it will bounce up past your max boost you have set on the dawes and then settle back down. Also having it too high you mid range boost level for 100k's will be higher too.
