Just want some heads up on the way the car feels with a 3" lift.
.............taller
Lol I meant is it heavy on steering?
nah mat, shouldnt make your steering heavier, unless your fitting a RTC or adjustable steering damper (RTC damper may or may not make it feel heavier). You may get a little more body roll but that will depend on rating of the springs
Don't use an rtc damper mate they are rubbish.
yep i have 3" lift and no different to stock inho
x 4
I agree with these guys, but I will also add that I think it has improved the handling and ride quality, compared to standard.
I have a RTC damper, I think it makes the steering a bit heavier, but I like the feel of it.
Evo
all good, but you may find people struggle to get in it hahahaha, I know I do lol.
Ummm i know i'm a noob to patrols but i also drive MC interstate.. I Cancelled my order of roof cage and have ditched the far rear seats in favour of storage to keep centre of grav as low as poss, from recommendation of forum members..
Love the high lift but am well aware of top heavy..
I'm now at 2.3 metres to roof lid with body and elrancho suspension lift on 35"..
Love the clearance and am use to sitting high, so i guess i wanted some of that too..
With the right 3 inch lift, it should feel and handle better than factory, even with the higher COM
I hate the factory feel it is very boat like
im pretty sure winnie runs a 3" lift... his truck runs beautiful
I run a 3" lift in the GUIV with drop boxes. Love it.
Been running dobinsons 3 inch for a couple of years, still with sway bars and everything. Love it. It leans a bit into corners but it doesnt ever try and leave the road. Also run a roof rack that has carried a fair bit of weight no problems.
Do recommend.
I couldn't afford the drop boxes at the time, so got caster bushes and replaced the radius arm to chassis bushes, and it's fine.
Evo
I am a motor mechanic by trade but can't say I have ever done bushes in a patrol before
THey just press out. If you have a press then happy days.
If your paying the shop to remove the radius arms, press out the factory bushes and press in the correction bushes and then refit the radius arms i'd argue it would be cheaper to buy and fit the drop boxes!!
These are the boxes i have in the GUIV NISSAN-PATROL-GQ-GU-FORD-MAVERICK-DROP-BOXES-3-6-INCH
There are a couple of cheaper ones now but all are copies of this bloke who made the first direct bolt in jobs. I have fitted superiors to the GQ first and they needed to have a slight cut, the ones in the link were a piece of piss to fit. And you retain the factory bushes which is ideal.
i was thinking about getting a 3". i was told i'd also need to buy Extended Sway Bar Link Kit, Extended Brake Lines and Offset Castor Correction Bush Kit. Do i need these.
Skits I would at least be putting it all in if I was you.
I have just finished putting a 2" lift in mine and in order to "future proof" in case I want to go bigger in the future I also invested in adj panhards, come spec draglink and adj sway bar linkages, I went with all Superior Engineering gear in mine. After having it squared up and driving straight my tyre guy recommended whacking in the castor bushes. Now there are mixed reports, some say do it others say dont worry about it but for a 3" I would be whacking them in.
I'm pretty handy with a spanner and a mate of mine has a hoist so where as paying someone to do it, we put the suspension in which I reckon I saved around $1000 in labour alone, so I had more cash to splash on the setup I wanted as opposed to what a local 4wd store / suspension mob might tell you what you need. Now provided I can pin down another mate of mine who I know has a press, I will be whacking in the castor correction bushes as well.
ok thanks for that,i still havnt decided weather to go for the 2" or 3".
