12 Attachment(s)
My car's history - roof off
Next thing I did was to take down the roof as I intended to buy a new suspension lift kit and the car wouldn't fit anymore in my garrage.
The roof for the utility vans is modified (I believe because they must have a certain load capacity). The modification consists of installing a fiberglass roof on top of the existing one, which is cut to make more room.
I started by dissasembilng the side panels for rear windows:
Attachment 39723
I dissasembled then the roof light support, the temperature and heading indicator from the front of the roof, the rearwivew mirror and other small things that were attached to the roof. I coud then take down the roof lining/cover (hope this makes sense - my english is not so good especially with technical terms).
Attachment 39714Attachment 39715Attachment 39716
Thext on the list was the roof window (it is a bit heavy 10-12 Kilos):
Attachment 39724
Next part was a little bit hard to persuade to come off as it was glued vey well to/through the original roof (fitted throgugh the hole):
Attachment 39717Attachment 39719Attachment 39718
Here it is how it looked like after taking it down:
Attachment 39720Attachment 39721Attachment 39722Attachment 39713
Next sep was to take down the external fiberglass roof; it was relatively easy to cut. Unfortunatelly I have no pictures with that operation.
I bought a piece of the metal rooftop from some guy who disassembles old/crashed cars and weld it over the hole in the original roof.
To be continued...
